Yes, we were
I have global OPEN but not the CLOSE. I wonder why and if the dealer can enable it?Looks like the boys from the F150 forum, was successful in enabling global open/close
BCM:
726-17-01 0101 0101 014A
726-17-02 0101 0101 014B
726-30-01 0101 0000 0060
DDM:
740-05-01 Dxxx xx
PDM:
741-05-01 Dxxx xx
I doubt it is a liability issue since my MKT had Global Open & Close. That is why I found it strange that the 2017 only has the Open.Liability issues for the close feature?
But yes, they should have the ability to add it as via IDS programming.
that would be great! waiting for it!These guys are on a tear, now they figured out how to enable side mirror auto tilt when reversing.
I will be testing everything out this weekend and will report back on what works on the EX and so far existing discovered feaures have worked.
If I remember correctly, the Global Open will only work on windows with the 'one touch' feature. I'd be interested to see if you can get that to work so maybe I can get the 'Close' part to function.These guys are on a tear, now they figured out how to enable side mirror auto tilt when reversing.
Wow, that is great! I'm going to enable that as well. Interesting then, why it doesn't work thru direct bcm config...I'm happy to report that global open/close works for both front driver and passenger windows.
I also "unhid" it in the instrument panel cluster and can enable/disable both functions or one only.
In your case Peter, it looks like the factory disabled global close on your EX.
Pretty much everything listed in Livinitup's spreadsheet can be enabled on our EX.
