Flye
- December 23, 2004
- Virginia Beach, VA
- '96 XLT
1996 Explorer XLT, 4.0L OHV
NEW Steering Rack
Several issues/Questions:
-Filled Pump tank, Idling, all seemed fine
-Wheels off, Exp on Jackstands
-Slightest turn on the steering wheel leads to "Violent Shake" (and that may actually be an understatement in this case)
-With motor off, and turn on steering wheel, if you turn with any real vigor, the wheel is very hard to turn. If you back off and just slowly turn it, you can slowly work it back and forth. turn too quickly and it gets 'hard'.
-Some searches indicate 'air in system'. (Some suggestions in other posts were 'take it around block, working steering wheel back and forth'. That ain't going to work with this level of spin/shake.)
1) Any suggestions on how to get air out? Driving is out of question. Any 'best practices' on using a 'mighty vac' arrangement and best way to get a good seal on the pump cap?) I've seen 'get a rubber plug' and put barb through it....
2) Can anyone explain the O-rings (white teflon, black rubber) on where they go? I'm not sure the ones that came with the rack were specific and there was only one 'larger' one. Where do the small black rubber O-rings go? I found No black rubber O-rings on the old rack. The white teflon/nylon (white) looking O-rings seemed to have been on threads? Are they only for thread seal?
I'm seeing 0 leaks, so I'm not certain the air/shake is related to the O ring thing or just 'air in system', but might as well have it right.... A BBB video states the return line is on vacuum, so perhaps I'm sucking air on the return line fitting?
Is there something that might be wrong that I'm overlooking?
Again, suggestions of 'just turn it lock to lock a few times' is not going to work. The split moment you touch the steering wheel, it goes into a violent back and forth shake.
Thank you for any assistance.
NEW Steering Rack
