Flip4ford
- August 24, 2006
- Newton, KS
- 94' Sport
After the loud bang taking out the transmission, transfercase, stubbler, driveshaft and rear locker- I have a new to me exploder.
This one is a 93 sport not exactly ulike the 94 I had. (even same color)
Did the soa set up with 4 door rear leaves.
All new seals and bearings and a powertrax for the rear!
A james duff 5.5 up front.
I tackled every bearing seal and new powertrax in the front end.
Did a disk brake mod for the rear- which was easier then I anticipated- I bolted the new hardware on and used 97 e-brake cables. Had to make a small braket for each side but it went well.
New master cylinder from a 97.
4:56 gears all the way around-
All new brake lines, calipers and pads.
New "Solid" rear diff cover.
Guess I am set for awhile--- What a busy long weekend (at 100drgs too)- Started on the 4th finished Sunday afternoon at about supper time.
Now that I am done bragging I just want to thank all the hundreds of posters' and info I gathered to make this possible. Can't do enough research.
I'll tackle the BII tank and stubbler in a month or so when things slow down.
Pics in a couple days after clean up! My yard is a mess with left over parts.
