Blown
- December 6, 2007
- Montrose, CO
- 2017 Sport
It starts and runs on the battery. It is chiming 5 times, a low battery indicator or charging chime???
I have checked fuses and wiring. With KOEO I got no power at the "I" terminal. I got battery voltage at the other Alt. terminals. The battery/charge indicator does not light at key on and does not light even though it is not charging. I pulled the instrument cluster and checked the bulb, and it's good. I cleaned the races/contacts on the cluster and swapped over a working bulb to be sure. It still did not light
It appears that circuit is bad. Can I jump 12 volts directly to the "I" terminal to turn-on the Alt? I am thinking that would be a good test to confirm the alt. will work with power applied to the "I" terminal. If that works I don't need an Alt. but to do some wiring, trace and fix that circuit.
