zhanx
- April 6, 2004
- Up state NY
- 2000 xls
Well, got my explorer back, Wont crank. Did some troubleshooting and I think its the clutch sensor.
I swapped to a manual transmission a few years back n (thanks again joshc). When I left for Korea my explorer went into storage. and since basically 07' it has sat in storage.
So new battery is in. I towed it about a thousand miles to my new place. Engine rotates. But cranky. Pulled the starter relay and can get the starter to engage when jumping the pins up top. No voltage on pin 85
. Also don't hear the fuel pump kick on. Without a wiring diagram right now so *IF* someone has one please post it. Also a casual search for the starter connections didn't show the wires but. Top post is hot bottom is ground I hope. My awesome father changed the starter for some reason and didn't connect the wires. Good thing he never turned in the core and I was able to get the solenoid wire off it. After 7 years I get to rebuilt / refresh everything. With a bonus of squirrels making a home out of my rear bench seat.
So tips and Ideas..... Also have a computer to change out the PCM to a manual in instead of automatic transmission when I can get the thing running.
