dogtown01
- August 20, 2013
- California
- 1993 ford ranger v6 4.0
hi guys, i need some help big time my truck broke, and i am in need of some help. i have a 1993 ford ranger v6 4.0. the original problem i was having is my truck was dumping to much fuel into the engine causing fuel to fall into my oil pan. i only have 89000 miles on this truck and it needed some over haul so i change the coil pack, the pcm, the fuel pressure regulator, new battery, new o2 sensor, new fuel injectors, new alternator, new coolant temp sensor, and after doing all these things hoping it will fix my problem my car developed a new problem. when i turn the key i get no spark and no gas. so than i did these steps to try to fix the problem. i check the fuses all seem to be ok. i droped the gass tank to see if the pump was good and it was good. i put 12v from a power supply i have and the pump kicked on and held good pressure. i checked the coil pack to see if it had 12v going to it and it did so why arent i getting spark and gas. i have no clue can any one please help me.
