dieselphreak
- January 3, 2016
- GR, Mich
- '97 5.0 AWD
Hello, new here, but long time shadetree wrench and Ford fanatic.
Just got done replacing the heater core in g/f's '97 5.0 AWD. What a PITA that was. So, now, i have a no start condition. Will fire on starting fluid. Can't hear a fuel pump come on with the key. I have a P0232 code. A couple others, but thats the only fuel system related one. I have checked the interia switch, button is down. Swapped the FP relay and no change. I'm fairly new to my MT2500, but it doesn't show much of anything in the data area that looks out of the ordinary.
But, the ABS light is on, there are no stop lamps. I notice fuse 13 in the interior fuse panel is PCM, stop lamps, and abs. But, fuse is good. Replaced it anyways, no luck. Just seems odd that all the items for that fuse are giving me fits.
There was a connector, in the dash between the radio area and the airbag pocket. Blue, four large wires. Never did see where that was supposed to plug into after searching for an hour. I just left it for the time being.
No check eng. light. No flashing "theft". Just no start, and no stop lamps, and the ABS light on. I'm at the end of my knowledge.
Any help is appreciated. I'm finding this Ex is a far more complicated little bugger than the 92-96 fullsize trucks i'm used to.
