If you put in gear oil you may have messed up the clutch. The case does use a viscous clutch. Look it up. It’s also the main reason of failure. Did you change the coupler gear with rebuild. All awd cases have one. It’s what helps the front tires do the 5% less driving and not allow them to get eaten up. Most awd cases you either put in a slip additive or friction additive. Ford used the same clutch as earlier trans I suppose. This trans fluid is no friction and all detergent meaning to operate properly it needs to be clean. I’m sure even my boy brookes agrees with this. Or awd cars would crow hop everywhere they went.
And ok no additive. I can name 10 cases that do for this one that doesn’t. Most awd cases use it. Much like the posi rears because fluid along doesn’t have proper friction modifiers. Never stated to know anything about “this” case at all. We’re a few ideas to check as the approach to remedy is similar for almost and brand or platform. However there is a viscous clutch gear. Maybe address that issue as well as possible places to look. As for English. Here are some synonyms of tilt. Tell me where you think tilt means an action word? SYNONYMS. slope, list, camber, gradient, bank, slant, incline, pitch, dip, cant, bevel, angle, heel. Something can easily be fixed and have a tilt. It does have to articulate at all. It can. And can be used to describe something that CAN be moved, but must be to an angle. But to tilt it must not be flat. Thus at an angle. Making my statement of it having a tilt 100% acceptable. Smfh
