not running right in morning
slowtruggy
lumberton tx
1994 explorer
my 94 explorer not running good in cool morning about 50 mph and above on my way to work it's like it don't have a lot of power but when I get off work in the afternoon runs just fine I have no engine lights on I just don't know
FR-425
Used to be a road here.
Phoenix, AZ.
1994 Explorer Limited
Sounds like the PCM Temp sensor is bad.
There are two - one for the gauge and one for the computer.
The one to the rear of the thermostat is the one for the PCM.
Looka lika dis ( the gauge sender does not have the pointy tip)
slowtruggy
lumberton tx
1994 explorer
Ok thanks I will change it
J Help! No start, fuel pump constantly running Stock 1991 - 1994 Explorers 3
J Running Boards Stock 1991 - 1994 Explorers 2
K Running rich Stock 1991 - 1994 Explorers 34
F SOLVED + TRUCK PICS: Truck Starts On Ether, But Wont Stay Running? Stock 1991 - 1994 Explorers 10
D finally got it running. Stock 1991 - 1994 Explorers 7
S Canadians? Daytime Running Lights Question Stock 1991 - 1994 Explorers 0
RangerX Any long term harm in running 100% Lucas in my power steering? Stock 1991 - 1994 Explorers 4
S Daytime Running Lights Stock 1991 - 1994 Explorers 0
B New to Forum, Rough running. Stock 1991 - 1994 Explorers 6
J Intermittent rough running, Code 214 Stock 1991 - 1994 Explorers 6
M Key turned off explorer would not stop running Stock 1991 - 1994 Explorers 4
B finally got my explorer running Stock 1991 - 1994 Explorers 6
T temperature gauge drops below cold when running Stock 1991 - 1994 Explorers 7
9 Rough running/Sputtering Stock 1991 - 1994 Explorers 7
K Not running well and needs help before it gets traded for a TOY! Stock 1991 - 1994 Explorers 32
G 94 Explorer Running High Stock 1991 - 1994 Explorers 14
T Solved [FIXED] Running extremely rough/rich on cold starts (w/ video) Stock 1991 - 1994 Explorers 13
J 93 ranger won't stay running Stock 1991 - 1994 Explorers 3
T Running warm! I think Stock 1991 - 1994 Explorers 4
K help running out of time Stock 1991 - 1994 Explorers 4
S Running issues Stock 1991 - 1994 Explorers 23
T stalling and running rough after warning up.. Stock 1991 - 1994 Explorers 15
A starts sometimes does not stay running Stock 1991 - 1994 Explorers 3
P 1993 explorer starting/running problem Stock 1991 - 1994 Explorers 7
M 92 Ford Explorer XLT starts chugging & check eng lite after running good for 15 mins Stock 1991 - 1994 Explorers 3
9 Some Weird Running Issues Stock 1991 - 1994 Explorers 2
D codes for rough running stock 94 Stock 1991 - 1994 Explorers 3
A Starting/Running issues Stock 1991 - 1994 Explorers 1
Bix rust eating bottom of rear seat running board area. Stock 1991 - 1994 Explorers 2
S Relocating MAF, code 66, long story, barely running? Help? Stock 1991 - 1994 Explorers 18
A Disabling Daytime Running Lamps (DRL) Module for HID Headlights Stock 1991 - 1994 Explorers 9
E Quick question.....vacume line running down..... Stock 1991 - 1994 Explorers 4
F Running rough all of a sudden! Stock 1991 - 1994 Explorers 1
W Tranny fluid out of starter while running Stock 1991 - 1994 Explorers 1
N running rich, code 42, does not switch Stock 1991 - 1994 Explorers 4
K New amp, running speaker wire Stock 1991 - 1994 Explorers 3
T 94 explorer running hot Stock 1991 - 1994 Explorers 2
R Running rough with AC on Stock 1991 - 1994 Explorers 4
D 93 explorer not running Stock 1991 - 1994 Explorers 4
F Engine Codes and Running issue help Stock 1991 - 1994 Explorers 22
F Engine running hot and no heat inside - Thermostat? Stock 1991 - 1994 Explorers 14
R Acts like I'm running out of gas after engine warms up Stock 1991 - 1994 Explorers 14
L running issue question Stock 1991 - 1994 Explorers 2
K running lights Stock 1991 - 1994 Explorers 5
Y reading 4wabs while vehicle is running Stock 1991 - 1994 Explorers 0
M not sure if my motor is running 100% Stock 1991 - 1994 Explorers 4
G Running rough after head gasket rebuild Stock 1991 - 1994 Explorers 14
D Running Lean, Poor Mileage and power Stock 1991 - 1994 Explorers 12
N Parking/Running lights short? Stock 1991 - 1994 Explorers 31
A First Gen Eddie running boards onto 92 XLT Stock 1991 - 1994 Explorers 1
Similar threads
