Stynx
- April 11, 2022
- Springfield, PA
- 2005 Explorer XLT Sport
I finally got around to cutting out the rust on the right rear fender of my 05 xlt sport. It was basically at the top of the "arch". After removing the plastic trim I cut out the rusty parts with an angle grinder, cleaned it up with a wire brush wheel, then cleaned it with brake cleaner. I cut 2 pieces of fiberglass cloth to fit and glued them on with resin, then filled in with body filler and sanded it down into shape. Overall it turned out pretty good, the next step is priming and painting it.
The odd observation is that when I went to walmart to pick up some stuff, I did a double take when I saw an explorer virtually identical to mine in the parking lot. What stood out what it was clean like mine EXCEPT for rust in the middle of the right rear fender and no place else.
What is it about that side that makes them rust in that spot? Anyone else get rust there?
