pope_face
- December 9, 2006
- Vancouver, BC
- '91 XL 4x4
Alright, I know this topic has probably been beaten into the ground, and I know there's an offroad fabrication forum, but I have a first gen Explorer and this is where I'd rather get some input...
I've done a little research on the BII tire carriers, so I've found out that I won't be able to fit one without serious modifications... Or, at least not a stock one. The next option is a bumper mounted tire carrier... seeing as I'm cheap and don't want to buy an aftermarket bumper, and because I don't want to hack away at the body too much, I want to make my own...
I'm going to be making my own bumpers anyways, but I was considering removing the little chromed panels just behind the rear wheels... I'm not sure if those are separate panels or if they're part of the rear quarter panel, but they're getting hacked off. I noticed that the frame just behind those panels (by the gas filler neck on the driver's side and above the tailpipe on the passenger's) has holes already drilled in it... so I'm considering making custom bumpers and mounting them to the stock location as well as wrapping them around the sides up to the rear wheels and bolting them to the frame in that place as well. That should allow me to have a heavier bumper that can support more weight as well, or at least more weight on the sides. Then I'd run tubing up from the bumper on the passenger's side, right behind the taillight, and bolt it to the body to keep it from wobbling too much. I know I'll have to reinforce the body behind it, but I'm planning on using like a 4"x8" sheet of steel on the outside to spread out the weight, and a similar sheet on the inside. I can't weld the body panels because I don't have enough experiance, so I'm going to stick with the bolts. Then, weld a piece of angle iron to the tubing for a mounting surface, and weld a couple door hinges to that. I could then make the tire carrier itself to wrap around the back and lock to the bumper (rather than the tailgate) and use door hinges to hang it. All that would be left would be to mount a ladder onto the tire carrier.
I'd make the ladder sit partially on the bumper itself when the assembly is closed... that way if I climb up and the assembly shifts, the bumper will take the weight rather than the body. I did have a question though...
If I go with this route, is it possible that I could put too much strain on the body where the assembly bolts to it? The last thing I'd want to do is gouge a huge hole in the side of my truck and have my bumper fall off... Any comments/suggestions?
