LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Starting yesterday, my "check, gauge" light started coming on briefly. Today I noticed that when I came to a stop, the oil pressure gauge reading would drop to 0 and the light would come on. When I started going again, the reading would come back up to normal and the warning light would go off. The oil was low, so I added more oil, but now it is even worse with the reading staying at 0 for longer periods of time. Other than that, everything else seems normal. The engine is not running hot, there are no unusual noises or changes in performance.
Is this likely an instrumentation issue or a problem with the oil pump? The way it goes on and off, its seems to be acting like a flaky sensor, but the system is a bit too important to ignore and hope for the best. There defiantly is enough oil in the system, so it there anything else I can check to make sure that the oil pump is actually still working?
Help would be greatly appreciated, I am going on the road tomorrow and this is not a good time for engine trouble.
LMHmedchem
LMHmedchem
