Ah I see.
You want a ported upper intake manifold and yours is plastic.
You can use the manifold from a 91-94 I believe, just use the sensors from your later model 4.0L? Is this for the 2000 EB in your sig?
The plastic upper plenum keeps the intake charge much cooler = more power.
So you might be shooting yourself in the foot.
Also the OHV 4.0L uper intake flows quite well and is by no means your smallest bottleneck. in fact even high performance built 4.0L OHV's may only get slight de-burring and gasket mathcing on the upper and lower intakes. You can also make a phenolic spacer to go between them to keep the intake air cooler.
If you want to make power look at having the heads worked on a bit, this is where the OHV 4.0l will really benefot from porting and polishing.
What performance mods do you have already?
