tomtom4049
- August 18, 2012
- Charleston, SC
- 93 Ranger XLT 3.0 w/A4LD
Thanks a bunch!
I have a 93 Ranger XLT that I modded with a 1999 Explorer O.H.C. It worked for a couple of months no problem. One day coming home I noticed the display was out, mode change didn't revive it. I cried out, Well Horse feathers! I read your info on this problem & took mine apart for a look-see. One of the surface mount resistors had lifted (dropped, in the while-mounted position). The other was still soldered OK. Resoldering wasn't an option in my case as one end of the lifted resistor's silver end-connections was history so there was nothing left to solder to. I dashed out to Radio Shack and bough a five-pack of 47-Ohm * 1/2 watt Carbon-Film resistors. Their PN: 2711105 $1.19 less tax. I removed the still attached surface mount resistor too and fashioned the resistor leads of the replacements to look roughly like Mr. Potato Head's ears and soldered them in place. Reassembled the O.H. console and it lives once again. So "Many thanks" to your ingenuity! I would have found the problem eventually but you shortened the inspection curve significantly. :rangertan:
I previously did a little modification to the console by adding a single amber 12 volt LED situated between the two map lights. I wired it into the dash lights connection so at night I can see the area where my cup holders are (between the seats) as it is now softly lit. That area was in total darkness before. I stole this idea from my Jaguar X-Type, which has a similar LED that lights the cup holder area. It isn't at all distracting while driving. A nice touch.
