Joes4x4Ranger
- August 7, 2006
- The center of Hell, Parker, Arizona!
- '91 XLT
The last thing I need to figure out with my '91 OHC install is if I can run very short sheet metal screws to hold the metal bracket to the roof. Or will they poke through on the outside?
I searched and searched this forum but could not come up with an answer. I know the '93's and up had some threaded screw holes to mount the metal bracket. All I need to know is if the roof on my 91 is double walled in the area where the bracket goes.
If worse comes to worse I'll use a heavy dose of 2 sided trim mounting tape.
