Pan Drop | Ford Explorer Forums
Pan Drop
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
Ok, I have the spontanious erge to do a pan drop today. I've searched for about a half hour and came up with very little. I'm dead set on a pan drop, don't mention flush. I don't want to hear it.
So I'll need new filter(non metal one) 6 quarts of fluid(?) and thats basically it? There anything I should tighten down while I have the pan off? Thanks for the help.
You will only need 4 quarts of fluid since you have the OHV. Just change the filter, change out the gasket, and add some fresh fluid. If you don't mind adding additives, I used a can of SeaFoam Trans-Tune and it has made a noticeable difference in shift quality.
