jeff4912
- July 27, 2006
- Seattle, Wa
- 2003 Ford Explorer 4WD
I have a '03 Explorer 4.0 V6 with PCV on backside of valve cover on drivers side.
I find sometimes that I have a little oil leaking out of the pcv where it goes into the valve cover and runs down the valve cover...is this normal?
I took the pcv valve out and reinstalled it, and when fully seated, it rocks a little if you pull back and forth on it thus giving room for oil to blow by sometimes.
The rubber o-ring gasket is there, and the pcv is 30k old.
