Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
My truck has 140,000 on the clock and I recently noticed that it is sending a lot of oil through the pcv valve on the valve cover back into my intake.
I cleaned my TB about four months back and when I recently cleaned it the other day I noticed it was filthy with oil. In fact you can see oil around the PCV valve cover valve that the hose conects to and inside the intake tube.
I imagine this is coating the plugs with oil possibly causing them to foul out at times.
I think I have two options, the first would be to get the oil seperator thingy and run it betweent the valve cover vent and air intake hose. Or just screw that system all together, plug the hole on the intake tube and use a small K&N vent tube. Besides the legal emissions issues would this work? I think Monmax has his configured this way.
Thoughts or suggestions?
