jbwilli
- February 14, 2012
- marietta ga
- 1997 SPORT 2009 EXP EB
I am chasing a PO401 EGR Code. I suspect the black plastic vacuum line to the EGR may be clogged, broken/etc. The pn 6L2Z-9E498-A VACUUM harness has 3 black and 1 red hard plastic vacuums line within in. The large end of this harness connects to the top of intake where it gets it's vacuum source. All 4 of the lines end in that intake connector. One of the black lines runs inside the harness all the way to the one-way check valve on the firewall behind the EGR that controls a blend door. Another paired black and red line run inside the harness all the way to the EGR where they end into a rubber 2 port but one-piece vacuum elbow connector to the EGR. The final and 4th line is black and from pics of the harness, it appears to run inside the harness and under the intake where it terminates into a one port rubber elbow connector under the intake. This line does not run inside the harness all the wy to the EGR, bu tonly half way to the connection under the intake. I disconnected the harness at the large end at the intake connection and plugged it off. Behin the EGR, I disconnected the single black line to blend door AND the rubber elbow connector to the EGR. I pulled a vacuum on all 3 of these lines individually. The black line to the blend door and the red line to the EGR held vacuum. The black line to the EGR would not hold a vacuum. 1) is that normal. I cannot access the 4th black vacuum line connects under the intake to perform a vacuum test on it! This harness and where the 4 lines run inside of it have me confused. Any help or comments would be appreciated. I ordered a new one. When it gets here, hopefully I can figure it out! THANKS!
