Currency
- September 11, 2009
- Bedford Indiana
- 94 XLT 4x4
Well I have posted on here a lot and seem to come and go as well. But I always come back and have helped out some fellow explorer owners, on here and in real life.
I've posted on here before about a sound coming from my front end, could be hub, axle, or shaft to the transfer case or even the transfer case.
It sounds like the driver side hub is locked in at speeds under 15 MPH and it has made the sound for over a year with me checking everything I would think it was and now it's even worse.
Now it makes more of a chunking sound at any speed under 15 MPH. Sometimes it makes a different and more painful sound, sounds like gears grinding.
So I crawled under it yesterday since I could not find the handle to my 3 ton jack in the mess I'll call my garage 16 foot by 24 foot.
I poked at things, turned this and that, and think I found the issue.
The sound always came from the driver side area around my feet when I'm driving. I think it's the transfer case as the shaft from the transfer case to the front end makes a clicking noise if I twist it even a little bit by hand.
Anyone have any suggestions as to what may have caused this problem?
It's been like that since I've had it and has not gotten to the point where I need to come up with a cheap fix as I do not have the money to shell out for a new/used transfer case but will if I have to.
Know this is not the modified 91-94 section. But would it be easier quicker to pull that front shaft thus making it rear wheel?
Would this cause fluid to leak out of the transfer case?
If that won't work, would it be best to change out the transmission bell housing or what not to a two wheel drive one and swap drive shafts?
I know where I can get another explorer right now for near junk prices, a local car lot has it and has been parting it out for years now. But I think that explorer is also four wheel.
My information is in the registry linked in my sig.
1994 four wheel drive, four door, XLT. 209k miles and finally trying to give out on me. :roll:
Thanks everyone.
Thanks everyone.
