JTH1972
- June 8, 2010
- Kelowna, BC
- 96 XL V6 4X4
Hey all,
For starters, what should the pressure be on a new fuel pump? I got in installed yesterday and my issues were definitely the fuel pump! Much better response, acceleration, and no hesitation or jerky driving. However, according to my pressure gauge, I'm only getting around 30 psi. I thought I read somewhere that it should be around 35-40 psi? I've also recently replaced the FPR and fuel filter so that shouldn't be an issue.
Surprisingly, the tank was a lot cleaner than I expected. There was some sediment present (and small pools of water!). Fortunately the project took longer so I was able to drain and let the tank dry overnight. Next day I cleaned out most of the sediment. The pump itself was remarkably shiny on the inside of the tank. I know Carter made pumps for Ford, but were they stamped with the ford name or the carter one? The one in the tank had the Carter name on it. Suspecting this pump may have been replaced once before?
