Power Liftgate when using foot sensor | Ford Explorer Forums
rtrip
westport, ct
2021 Explorer Limited
When I use the power liftgate using the foot sensor - the door does not open all the way (it stop about 3/4 of the way up). However, all other times, it opens all the way. Is this a setting that I can change?
Thanks in advance.
Push it open and try it again.
Thanks in advance.
The door should open consistently to the same height whether or not you have actually set the desired height. As Sea_Ray suggested, open it all the way, then press the set height button.
See if that fixes the issue.
