Power Liftgate | Ford Explorer Forums
Power Liftgate
Neisha14
Columbia, MS
2016 Ford Explorer XLT
HELP!!!! I have a 2016 Ford Explorer XLT. When I let my liftgate up it immediately slams shut. Have anybody else had this problem or may know what’s going on?
Welcome to the forum!
Can you elaborate on what you mean by "When I let my liftgate up it immediately slams shut"?
Do you have a power, or manual liftgate? If manual, I'd guess that both your strut supports (AKA Lift Supports) are worn out. There is a seal and high pressure gas inside and once the seal leaks, they lose lift strength. If a power liftgate, I suppose it's still possible that the right side strut has worn out and the left motorized strut, is not powerful enough to keep it up.
Welcome to the Forum. :wave:
If you have a power liftgate then it could be that the motor (actuator) is not working. Liftgate for 2016 Ford Explorer | Levittown Ford Parts
If you don't have the powered 'gate' then it could be the support struts that are the issue.
Levittown is a forum vendor and gives members a discount. Coupon Codes for Forum Members
