Power Outlets - Are they Switched? | Page 2 | Ford Explorer Forums
I've merged your thread with this existing one. I think you'll find your answer here.
You could power it through the 120V. That's switched.
Oh and the Explorer is smart enough to not let something connected to 12V drain the battery completely. It would shut it off before it got close to going dead so there's no real problem eitherway.
Car Lighter Power
Does the power ever go off in the car lighter/usb connections when the car is off?
2015 Explorer
I believe the car lighters always stay on but the USBs come off.
That is what I have found as well. I keep an adapter handy in case I want to charge my phone with the Ex off.
I wish it was the other way around. I have had a cordless radar detector and decided to upgrade to the Escort Passport Max2. I was hoping I wouldn't have to pull it out every time I turned the car off...
In mine using a 12v to USB adapter, power lite stays lit on USB adapter after car is turned off.
I left it for a while, longer than the 10 minute(?) battery saver feature, so those plugs seem to stay on.
No idea if eventually they would turn off to due to battery saver,
I would hope so...
I would hope so...
How much power is being drawn from just a little blue indicator light do you think?
It's irrelevant as to how much power the LED is drawing. The point is the accessory power remains on as long as the battery is connected and charged. The battery saver feature kills all designated circuits after ten minutes of key off.
To the OP if you can wire the Escort to the mirror, that way it's on with the ignition and off otherwise.
So you think if you had a radar detector plugged in....after 10 mins it would shut off?
I love that the 12v outlets are "hot" and can charge my phone if needed vs. shutoff like my previous KIA or my past and current VW
Again, if the circuit it's connected to is designed to go to sleep after the 10 minute key off timer expires: YES. If the circuit is otherwise HOT at all times, the battery saver system would kill all unnecessary power after an extended period with no user activity (door opening, remote/keyless keypad button presses, etc.) if it felt there was sufficient power draw.
In my 2010 the cigarette lighter stays hot continuously and I know that because I have a back-up camera system installed and the screen standby LED flashes. I see it flashing anytime I look even if the car has sat untouched for days.
For those of you who haven't experienced it, I've had an alternator go out on my older Lincoln. As the battery voltage started dropping, the car would shut systems down to conserve power for essential systems: Radio, electronic climate control, mirror power, windows, cigar lighter, even the ABS system would be taken off-line. At that point I knew it was not going to stay running much longer, but I drove on rural roads and the highway for over an hour on a 1000CA battery, including a warm start.
In any case, would the LED pull enough to force the car into sleep mode: most likely not. However it's not just the LED if the detector is on, it doesn't care if the car is moving it is actively looking for signals to alert to, so how much power is the entire detector using 'at rest' looking and during an alert...
2015 Explorer
Using the forum's 'search' program I found the this thread and merged yours with it.
Dumb Power Point decision on Platinum
Well, after all the agonizing we finally bought a 2016 Explorer Platinum. Generally love it but there are a few changes or additions that are frustrating. I'll save that for later but right now I'm looking for a solution to a change Ford made to the Power Point behind the third row seats. For whatever reason they no longer provide continuous power to the plug. Our 2011 Limited had the power after the engine had been shut down.
What does Ford suppose the owner is doing with the Power Point? It's protected with a 20A fuse so I'd guess they don't expect it will be used to supply LEDs.
We have a compressor refrigerator that we have used for several years while traveling on long trips. We have never had a problem running the unit overnight as we stopped at hotels.
The change is a real disappointment. Is there a way to rewire or change the way the power is supplied to the rear Power Point?
A good 12v guy and a reputable local car stereo customizer should be able to take care of that easily.
Did they disable charging on all the power points in the 2016 explorer after ignition is shut off?
Power Points do not operate when the car is shut down.
It appears so. As far as I can determine none of the power points function after the key is turned off (or the keyless button is pressed)
That's annoying, we have ordered a limited explorer, and I loved the fact the power points stayed on after the vehicle was shut off.
That's too bad.... was nice to have
