Power Window Bushing Replacement | Page 9 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Patrickf1986
Indianapolis, IN
1991 Explorer XLT
85Dave your a life saver. I just picked up my XLT a couple weeks ago and all four windows won't roll up or down. The motors run but the windows go nowhere. Pulled apart the driver side dp and followed your steps and it turns out the inside of the gear assembly was almost identical to your picture. I'd bet my life the other three are going to look the same. Thanks for taking the time to post those pics.
smegun
florida
1994 ford explorer xlt
try a non petroleum based lube mabe they wont crumble
MrHendren
Lexington Ky
1994 Ford Explorer LXT
Hey guys just wanted to say I did this to my explorer yesterday and thanks to this write up my windows now all work! I did not replace them with a plastic bushing, but I did a metal ones. You can get a set (2 windows, 6 bushing) for like 6 bucks shipped. I highly recommend it.
http://www.ebay.com/itm/FORD-F150-E...r_Truck_Parts_Accessories&hash=item43bdb0e7b7
thats for metal ones. Id say they will last longer, so if your gonna replace them, might as well do it right.
Also these are made in the good ol US of A
tac
va
the plastic bushings go in easily if you coat them in Vaseline, put them in place with the gear on top, then press them using a bench vise. i did all mine this way and it is real easy.
Potomac30
IRMo, SC
1993 XLT 4WD
For those still going to do this job I found a good source for the gear pins:
http://www.natauto.com/wlk-52-torque-pins.html, they are $1.57 per set of three. Call them to have shipped USPS. This is my first post and want to thank everyone for contributing, very helpful.
Thanks for the link! I got 4 sets for $8.21 and I didn't even have to leave the house.
swimmernate
Idaho
1991 Explorer XLT
So I rebuilt my drivers side window motor like a month ago. It was working great for a bit, then I noticed it would hesitate a little then it stopped all together. I just took it a part and saw the plastic bushings were destroyed. What did I do wrong? Anyone else have that happen?
tree11
02 mtneer
over heat
my 2003 over heats while moving slow with a/c on.
does it need a electric fan?where do I get one?:usa:
vq5speed
1991 XLT Manual Locks
Stockton,Ca
Did you pack it with a lot of grease when you did it. My bushing kit came with a bag of grease.
Daniel77
Ohio
94 Limited 4.0
power window bushings
thank you 85 dave
just replaced the passanger bushings, was a breeze once i figured out how to get the motor out . Advance auto sells these bushings for $7.99 .
Thanks again
joey
FocusRush
Ventura, CA
1992 Ford Explorer XLT
This repair is almost identical to the headlights on my old Pontiac Fiero pop-up motors. The plastic bushings would just crumble over the years. I found the metal ones to be far superior. I'm sure the bushings are different sizes, but the process and design is identical.
I was about to buy a new motor, but now I can save the $$$ and just do this! Thank You!
West Covina
1992 Ford Explorer Sport
Is thia good for a window thats slow to roll up, or does something need to be replaced?
peter683
1991 Explorer
Excellent step by step "how to: post! I bet this is what happened to my pax side window..
trozei123
1992 Explorer XLT 4x4
does this method work if the windows "chug" down? my drivers window and drivers side rear window both chug down, but will not go up unless i push up on the glass. my passenger side rear window doesn't move either. i looked in the door, and it seems like the motor is not even connected to the window. there is a wooden dowel holding the window up. how can i get that one fixed?
peter683
1991 Explorer
Trozei, funny you mention it as my drivers window operates slowly to open but closes at normal speed I wonder if this is also bushing related?
tac
va
yes bushings are about shot.
it is just a matter of time before it quits.
you will understand when you see the bushings.
they will be disintegrated.
trozei123
are the bushings absolutely necessary? could i maybe use super glue to bond the center gear to the plastic one? i am always broke and cant really afford to get the bushings.
trozei123
success!!! i have both drivers side windows fixed! the big challenge was not having the right size drill bit for the third bolt on both doors. i found a cheaper way to fix the windows. i used 1/4" hex nuts. i read that some people used 7/16", but i guess my motors were smalller. the nuts slipped right in. a good amount of vasseline on the gears and some wd 40 on the tracks, and my windows run so much better.
the last window i am not sure of. the cable is broken. i have to have a wooden dowel inside to hold the glass up. :( anyone know how i can fix that one?
