pre runner fenders on ebay | Ford Explorer Forums
95offroadx
Palmyra, Pa
91 explorer xlt
If you want to do the conversion I would get it from Perry's. It will look just like Ricks as he got his from them. Plus I think they give a little discount if you tell them you're from the Explorer board.
any discount is great news to me
does anyone know how much raise is on perry fenders?
i only have 33's and i dont want to much of a gap between the tires and the fenders.
Here they are with 33's
how much lift is on that xplorer?
Its Sk1ers. I think it has a 3" BL, and a 1-2" TT, with shackles in the rear.
thanks for all the help guys, i will be gettin perrys in about a month or 3(cash is low right now)
any rubbing problems? do you have a side view? what gear ratio are you running?
well i will be getting 1.5" f150 spacers soon to level it out so i will have a 5.5" lift, so i think 35's will look perfect
I'll try to find a side view. It only rubbed when suspension was totally twisted up in the passengers side front. That wasn't on the fender though. I had 4.56s which makes it as close to stock as you can get with 35s.
also how much raise is on the fenders?
rasie as in how much higher they are then stock from the ground up? or width of the fenders? they are normally measured in amount wider then stock....
how much high from the ground up
