MVisbal
- December 29, 2010
- Bethesda MD
- 1995 XLT
There are differences in wiring between a 1997 and 2000. So this may not apply to you, but I'll offer it anyways.
In a 1997 one wire (Red/Black) goes from the dimmer switch and powers both the Rear defrost switch illumination, Rear wiper illumination, Fog light switch illumination, and the Instrument panel illumination. All of those are also grounded through the same Black wire.
Since the former are working it would seem that you should look at the circuit board traces on the back of the instrument cluster. The plastic film they are on becomes brittle and warps. Check for continuity along the traces that lead to the illumination bulbs and look for breaks in them. Also check for loose wires at the electrical connectors for the instrument cluster.
OK, I have a 1995 Explorer XLT. No dash illumination or switch illumination around the radio. On the 1995 is the red/black ground wire off of the dimmer switch the same as the 1997 that you described in this thread?
Thanks,
Mark
