Question about Rear Wiper Please Help | Ford Explorer - Ford Ranger Forums - Serious Explorations
F
FordLoverXLT
Did replace the Following:
rear wiper motor
and wiper blade assembly
Issues: the rear wiper control switch will shoot wiper fluid to the back but will not move the wiper
Thinks: I could i just need a new rear wiper control switch
Fuse Issue Possibly?: I'm not sure If I need this replacement in my explorer, here is my situation I recently replaced the rear wiper motor assuming it was broken, the rear wiper switch will not turn on (control the motor, Making the wiper move up and down)..when I push the button it does shoot wiper fluid out the back I believe there are 3 or 4 fuses for the rear wiper 2 including making it go up and down
Fuse number 12 in the I/P Fuse panel and fuse number 8 in the power box, could that be the reason why the wiper will only shoot fluid and not move up and down because of maybe a blown fuse? please let me know
Fuse 8 Distribution box controls the rear wiper going up and down might be my issue?
My Make Model: 1998 Explorer XLT 4DR 4.0L SOHC 4X4 Auto
gonenuke
Virginia
1999 Explorer XLT SOHC
Is the wiper moving at all? Could it be getting stuck between the door panel and the back glass?
F
FordLoverXLT
well looking at the Fuse manual, Fuse 8 in the Distribution box controls the rear wiper going up and down maybe the fuse is blown and that's why the rear wiper control only half works. It will shoot fluid so possibly i'm missing a fuse or one is blown at that point need to check
F
FordLoverXLT
Found the solution the fuse was dirty I took it out and cleaned it put it back in the wipers work fine.
