twanhines
- July 2, 2010
- Florida
- 2004 Ford Explorer V6
As some of you may know, this past summer I've had some problems with gas mileage and gas fumes. Well I fixed the problem! Turns out the O rings was needing replacing. But with replacing the O rings, I was automatically obligated to replace the upper intake manifold gasket. Now that I've done that, the truck idles rough!! When I first start it up, it idles fine then it goes between 0 and 1 and then works its way up past 1 and then comes back to it. It drives perfectly fine, and accelerates great. But I was wondering if during the o ring and intake gasket replacement, was I suppose to disconnect the negative battery terminal? I hope this doesn't sound like a dumb question but I've been seeing different things on doing that to reset the computer. I just want my baby to stop that horrible idling!! It's scaring me. Please help, if I'm suppose to, is there any certain way I'm to reset the ECM computer, or just disconnect negative terminal? Thanks your college student twanhines:
