JMT1SOMR
- August 10, 2001
- Lakeland, TN * Oxford, MS
- '95 XLT
I can get 1" Body Lift block for $1 a peice and I was wonderign what else would need to be done with a one inch lift. Can I reuse the stock bolts? If no, then which ones need to be replaced and what are the bolt sizes? Will I need to lengthen the ground strap and drop the radiator shroud as well? I'm planning on doing the lift next week and I want to make sure I know what I'm doing. Assuming everything works out, the lift should only cost me about $15 and I plan on doing a write up w/ pics. Also, does anyone make a steering stabilizer for 2nd Gen explorers? I'm intrested in getting one. Thanks,
-Justin
-Justin
