Hey all. Wondering if these are indeed bolts or Studs host images
Yes, try heat on the flange on exhaust manifold side and an air impact. If you are doing manifold replacement there are some good write ups on this forum when you search.
I assume they are broken bolts in the manifold. Heat it up cherry red, and tap a large slotted screwdriver into the bolt and back it out. Works every time
