Rear Door Speaker Holes
Trader0000
Police Explorer for sale....needs paint
Glen Ellyn , IL
2013 PIU 3.7L
I wanted to replace my utility rear door panels with the standard rear panels so that I could better hear the rear speakers. I could not find a cheap set so I decided to see if I could cut a hole in the door panel. I removed the rear door panel and found a surprise. Ford had molded a speaker star pattern consisting of 28 - 5/16” circles into the backside of the door panel that matches the speaker location.
After removing the panel I plugged in my Harbor Freight Wood/Soldering tool with the pointed tip. Then I centered the hot tip in the middle of each of the 5/16” holes, making a small dimple. Now I took a 1/8” drill bit and made the pilot holes from these dimples. After the pilot holes were drilled I took a step drill and carefully drilled out the holes to match the 5/16” template rings that Ford had molded in place. I thought about covering the back side with speaker cloth but have not done this yet. Then I reinstalled the door panels. This mod greatly increased the rear speaker volume and has the looks like an 80’s style factory speaker. I may later drill these holes larger using the step drill.
adamsdell
North Wilkesboro, NC
2016 Ford Police Utility
I saw that on my door panels too and I want to do that. I will be doing that when it warms up, too cold here.
Looks good.
Fedon
Toronto, Ontario
Police Interceptor 2013
Did the same thing when i had the panels off to reconnect the latch cable.
Neitron
Kansas City, MO
13 PIU
Thanks for the idea, Fedon. Just finished connecting the door latch cable and drilled for sound in one shot.
unixadm
2015 PIU Ecoboost
I replaced my rear door panels with retail versions.
2013PIU
WALNUT CREEK, CA
2013 PIU
Nice job! I'm thinking of doing this or using a hole saw to cut out the outer perimeter of the circle and attaching speaker covers. Do you recall the diameter of the big circle? I've attached a pic of some $10 covers.
unixadm
2015 PIU Ecoboost
The prior owner of my 2015 PIU did the speaker covers and let me tell you, it looked GHETTO. Everyone who rode in the back of my Explorer always commented on my 1980's speakers. lol.
Hence why I swapped to the civi door panels which was a cheap upgrade.
nathansmith50
grand rapids, MI
2014 PIU
Not sure about all of them but this was the case in mine. Maybe yours too. If you care.
my kids were complaining that they couldn’t hear the music. So I grabbed some speakers at the pick and pull and was going to install them. I was hoping they had connectors but was ready to run speaker wire if I had to. Pulled the door skin and what to my wondering eyes should appear? There are speakers in there! There are just no grilles in the door card. There is a pattern on the back for drilling. So I drilled out the holes and covered the whole panel in speaker cover material. I didn’t remove anything from the door card. Some super 77 spray adhesive and a screwdriver to tuck the edge behind the panel.
I have pictures but I have no online hosting.
KayGee
Farmington, MI
'16 & '17 PIU
Online hosting is free. Imgur.com
I know this site wants to sell memberships, but you'd think there would be a stickied thread on how to post images (with and without a membership) as it seems to come up quite frequently.
nathansmith50
grand rapids, MI
2014 PIU
I figured out the pictures.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
nathansmith50.....your thread was merged with this one identified above by Jason.
nathansmith50
grand rapids, MI
2014 PIU
So I see. In any case. This is a nice in between. It looks, in my opinion, better than just holes or retail speaker grilles and it is a lot cheaper than new door panels.
DHG2496
Fruitport, MI
14 Explorer PIU 3.5EB
Would you mind reposting a couple pics? They don't appear to be working and I was curious how you finished the edges of the fabric.
nathansmith50
grand rapids, MI
2014 PIU
DHG2496
Fruitport, MI
Thanks @nathansmith50 i didn’t realize there was that much of a gap to stuff the fabric in there. Thanks for sharing the pics!
nathansmith50
grand rapids, MI
2014 PIU
Another step I neglected to mention, I think, I sprayed the whole panel that is covered with spray adhesive first.
Rob_I
New Hampshire
2013 PIU 3.7 NA
I'm getting ready to do the 5/16" hole trick. I really only listen to Audible (audio books) on my way to work, but having the rear speakers muffled behind the panel is irritating.
None of the other pictures in the thread are working except in the original post, but I plan to use some spray adhesive and this speaker cloth:
https://www.amazon.com/dp/B07F3YS99J/?tag=serious-20
I'll post after pics when I do it.
