seshore
- March 10, 2002
- Houston, TX
- '93 XLT
How do I get the rear window motor separated from the door lock actuator?
I should have been clearer, I have the door apart, speaker out, the dimple on the speaker hole drilled out (so the blind screw can be unscrewed, all the motor screws out (square head) and away from the inner door, but now it is hanging on the window actuator and I am unable to see how to get them apart. Advise on these doors, you only have to drill 1 hole to unscrew the motor as I did both front doors in an evening.
