96eb96
- October 20, 2004
- Albany, NY
- 96 EB V6 OHV 4WD
I have some occasional clunking while decelerating, also a bit of noise while revving in third gear at around 40-50Mph. Not a whine, possibly not drivetrain related, could possibly be from the cheap muffler.
I also have occasional vibrations past 65MPH, but nothing really major. There are new tires and balljoints(this didn't really make a big difference).
Anyway I put in in neutral, set the ebrake, chocked the wheels and went under the truck.
The UJoints SEEM tight, I can't get get play in any direction. Tried twisting motions and up-down. I guess the next test would be dropping the shaft, I know they could bind.
What I did find is this:
The driveshaft coupling near the t-case though had a bit play(don't know if this is normal). I was able to make it clunk by rapidly twisting both halves. Is this normal? I can't seem to find a spec on that. Would I need a new driveshaft or just the stub?
There is some backlash in the read end, but nothing that excessive. Both flanges feel solid with the driveshaft connected.
