REAR END 3rd SHOCK | Ford Explorer Forums
REAR END 3rd SHOCK
BIG JACK
jasper,in.
'95 xlt 199,000 mi.
Can someone tell me what that 3rd shock is on the rear end? Mine is sqeaking and needs to be replaced. It is located at the center of the rear end,like a stabilizer or something.
Some will say it isn't needed, but I say it is.
MONROE Part # SC2958
http://www.amazon.com/Monroe-SC2958-Magnum-Steering-Stabilizer/dp/B000C55SV4
I agree, I had trouble controlling my rearend when going around corners at speed while hitting potholes. (love those massachusetts roads) Was like trying to drive a dolphin down the road straight, until I replaced this.
Took mine off before the winter and haven't noticed any difference. If it's an off-road truck, leave it off.. better articulation. If it's a DD or street truck, find a nice one like Turdle posted. Monroe I've heard good things about, just haven't tried them. [I use Rancho]
Anyone have a pic of this installed? For whatever reason I do not remember seeing it when doing leaf springs, shocks, rear axle fluid & cover, etc etc... Turdle thanks for posting link to the shock part at Amazon. Have been finding some great buys there for Ford parts, MOOG parts, etc.
Just from what has been talked about on certain threads & various forums, I don't have any proof for myself on it. I could be wrong, but in my case I didn't notice any difference with it removed. [Don't know about articulation though.]
I chucked mine in the trash a long time ago, didn't notice much of a difference with it on or off.
Was told it does two things:
Helps a bit with axle windup too, think about it, when you accelerate the whole rear end wants to turn in the direction of the driveshaft, trying to lift one wheel off the ground a bit and the shock is there to limit that. Gives a tiny bit more traction to your rear end..
Also, limits to some extent lateral -side to side rear sway motion due to the the leaf springs. I'm thinking it may make the difference in an evasive maneuver where it damps the the lateral motion of the body giving you a bit more control.
The real world effects are probably very small.
I believe Ford put it in to kill the vibration issues from the rear that people were reporting. I don't think this shock will change anything when it comes to windup, but side to side it probably helps. I doubt it, but does your rear axle have traction bars? The V8 explorer's come with them.
Well, I got my new one installed,the truck rides much much better.
The old one was rusted into pieces.
Jack,
Can u post a pic of it?
Yay 5th shock thread!
For fun I removed the original one with 140,000 miles on it and drove around for a week while the replacement shipped. Handling was worse without then with the old one. By hand, the old shock still had some resistance too. With it off, the major problem was the way it would skip through turns. It would get scary hitting uneven road in the middle of a turn.
The replacement shock (posted above) was well worth the $25 and 10 minutes to install. It greatly improved handling, especially in turns. Don't believe the hype, fix it!
My Explorer never had one, to my knowledge. I'm trying to remember from a month or so ago when I was under there installing my locker, but I don't think it even has mounts or anything for it.
I also have one on my 1995 OHV...
Mine has been off for years and I have noticed NO difference,
When I first removed it, I tested it with it off for a week, reinastalled and tested for a week. There was NO difference I could detect in any way.
