Rear end | Ford Explorer Forums
Rear end
scottdunahoo
Detroit
01 Sport Trac
I have been hearing some crazy loud noises from my rear end of my 2 wheel drive sport track, well i just cracked it opened the fill plug and some came out and its really thin and black looking is this ok it runs almost like water
Sounds normal for the lube. I would change the lube and see if the noise persists. If the diff cover tag has an L on it then it is a limited-slip and you should put in limited-slip additive also.
ill try that thank you
