JasonF
- May 27, 2002
- 2004 XLT 4x4 4.0
On my 96 XLT, the rear inside door handle seems to be disconnected from latch mechanism. It only returns to within 15 degrees of where it is supposed to be. I can pull it as if opening the door and it travels to the end and still has the spring back if you let go of it, but its not moving any linkages inside the door. The outside handle and lock still work fine. No its not the child lock. Anyone had this happen? How hard is it to take the door apart and fix this? Thank you.
Jason Fine
Jason Fine
