Remote door pad doesn't work. | Ford Explorer Forums - Serious Explorations
manjin
bronx ny
03 explorer
Help, nothing hapens when I punch my code on my 03 explorer door. The lock/unlock button on the driver's side dosen't work and the keychain pad locks the doors but makes it churp as if there is a door unlocked. The lock button on the passenger side works. when I turn off the ignition the radio turns off immediately and the roof light stays on as if there is a door open. All these things started at the same time.
Another idea is to check for a broken ground wire in the rubber sleve between the driver side door and the body. Have read several people having same type of problems from the broken wire. Just my 2 cents. Good luck Pete
Welcome aboard! :salute:
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, etc. Most recently all 4 windows stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 2 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal. When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ.
Could also be related to the door ajar switch.
Here is the thread for removing the door panel: http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking/replacing the door ajar switch, thanks to borland for the awesome write-up: http://www.explorerforum.com/forums/showthread.php?t=249253
That is a great write up.
On a side note, before going through a complete replacement of the switch, you can spray WD40 into the door latch opening on each door, as these become stuck sometimes....and this can alleviate the issue.
This worked for me, after going for more than a year of the "door ajar" light coming on occasionally...mainly after a car wash, high humidity, or rain....making me unable to lock/arm the vehicle from the door keypad and keeping the dome lights on. Worth a try....it worked for me :thumbsup:
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums//showthread.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
Hope this helps out! :biggthump
