  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
How to: Replace Front Blend Door Actuator in 3rd Gen Ex.
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
they said I'd have to replace the whole blend door housing. I've tried to find the parts online but can't seem to find what I need. The part the mechanic said I needed comes a kit with the blend door housing and actuator. He said it would be expensive. Does anyone know what the part number(s) are to correct this?
I don't have the part numbers for the "Blend Door Box" you are looking for, but a Ford Dealership told me the "Blend Door Box" would cost approx $400.00, part only. The Actuator motor costs $82 + tax at a Ford Dealership. You can get the Actuator for around $62 shipping cost included, from Silver State Ford Products, they are a little cheaper. They have a web site. There is a fix posted on this web site to repair the Blend Door itself and there is a company that sells the replacement door kit to do this self fix. The ad for this blend door is " http://www.heatertreater.net/?gclid=COaQz63ux6sCFULe4Aoduj5o7A " also this " http://www.heatertreater.net/Ford Explorer 02-08.html " I want to say the part costs $15 if I remember the ad right and the fix requires you to cut a hole in the side of the plastic blend door box to access and R&R the blend door. Would save you a ton of money if you are able to do this type of fix yourself. Good luck.
blackhole72
2004 Ford Explorer
Thanks for the additional info. I considered the heatertreater option however I prefer not to perform this type of work. I received a quote for both the blend door box and actuator for 275, I'm going with this option. I'll post the part number if I get one.
bleoh
Maryland
'03 Explorer
Just finished this repair, thanks for the great write-up!
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Fordexplorer04
Hi; I need help. I am living in MN. I went to Ford dealerSSSSS looking for A/CHeater Blend Door Actuator for FORD EXPLORER 2004 XLT. They said, They don't understand what I am talking about. Would you please help me which way should I ask them or if you have a part number please give to me. My car is 2004 Ford Explorer XLT with manual AC/heat. Thank you
blackhole72
2004 Ford Explorer
This is the part number I received from Tousley Ford website for the actuator. 1L2Z-19E616-CA. I found out the blend door housing was much more than 275, probably around 500. Not happy with Fords, won't be buying again.
Edon
Yonkers, NY
2003 Ford Explorer XLT
i am a new member here i just want to thank you for this post you saved me $600 replaced it my self first time i ever did anything on my car besides clean it lol and my car is blasting heat like brand new ....i managed to replace it without cutting the dash with a 8mm box end wrench took me a long time and lots of patients but this thread was amazing and very very very helpful thank you again ...
Exproblems
Orchard Park, N.Y.
I was quoted $400 from a Ford dealership here for the Blend Door Box and the blend door actuator $82 was a seperate part that bolts on to it. Be sure you really need the whole blend door box and your blend door itself is bad, because you may just need a new blend door actuator. Ford guy said the actuator is usually the part that goes bad. Also, I hear you on "Ford Vehicles", I'm not happy with some of the problems I have had on this Explorer, especially these dashboard control issues for heat and AC, things that should never go bad, but what burns my ass is the lousy transmissions in them. I've had more Ford trannys die than any other vehicle I have owned in the last 34 years. I've also heard that Chevy's'/GM's aren't much better, have their own problems. In the future, I'll probably stick with a vehicle from one of the big 3 US automakers, because buying a foreign vehicle would make me feel Un-American, even if some of them are made in the USA these days.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
You are welcome. Glad I could help out!! :D
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Welcome aboard!! :salute:
The part number is specific to your vehicle. There is no 1 part for all the Ex's. You must give the dealer your VIN to ensure you get the correct part.
I just went into the dealer and told them I needed the front temp blend door actuator. They knew exactly what is was. I will check my shop manuals to see if I can find out exactly what Ford calls the part and post what I find out.
exford05
Anchorage, AK
2005 Explorer XLT
Thank You for this, made it really easy to get this repaired, I got a part from a part store that may not have been an OEM part but will work until I get an OEM part.
I was able to get this done without cutting the dash.
Thank You soo much for the post and I printed the pics into a booklet so when I get an OEM part I can do this again.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
gaw
Fort Worth, Texas
03' XLT
Not sure...
Yesterday I started hearing this when I switched from cold to hot on my '03 Explorer. It's not the quick clicking I've heard described in other posts. What do you think?
https://files.me.com/rpbc/viat7m.mp3
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Can't get any sound from the file. :dunno:
gaw
Fort Worth, Texas
03' XLT
Sorry the .mp3 is not working for you...it does for me...I can hear the door thump, thump, thump...not a quick clicking noise. If I turn the air to hot and put the fan to max, I hear a thump and then I've got hot air...
DirtySanchito
San Diego, California
'04 Ford Explorer
Big Rondo, did you go online and order the actuator? because I am online on fordparts.com looking for the part and i found a blend door motor, but am not sure exactly what part to get..
DirtySanchito
'04 Ford Explorer
Big Rondo, do you know the part number off hand? because i am on fordparts.com right now looking for the part and i found blend door motor but not actuator...and im not sure what part to get if im choosing from one of the blend door motors..
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Sounds like you are having the same trouble I had. The "thump" hear with the fan on max is most likely the blend door being blown shut. Same thing was happening to me.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
I got my actuator at my local ford dealer.
You need to give them your VIN to ensure you get the correct part. There is no universal part number. The part is VIN specific.
You need the temperature blend door actuator.
Wasntmee
aamcap@gmail.com
aamcap@gmail.com
Many Thanks!
Wow.
K Does anybody knows the cost of the labor to replace a front transfer case on a 05 Mountaineer? Stock 2002 - 2005 Explorers 4
B Need to replace drivers front seat foam.. Stock 2002 - 2005 Explorers 3
S Front turn signal replace screw part number Stock 2002 - 2005 Explorers 1
J Front Upper Control Arms - can I just replace bushings? Stock 2002 - 2005 Explorers 6
R ABS light came on after Left front Hub replace Stock 2002 - 2005 Explorers 11
M replace a hub and bearing front detailed video! Stock 2002 - 2005 Explorers 3
E Front sway bar link remove and replace Stock 2002 - 2005 Explorers 2
F Remove/Replace Front Bumper Cover Stock 2002 - 2005 Explorers 1
N Driver front wheel hub replace Stock 2002 - 2005 Explorers 1
J Front CV Axle - Repair or Replace?? Stock 2002 - 2005 Explorers 7
J how to replace front axle output seal Stock 2002 - 2005 Explorers 0
J need to remove and replace front wrap on 2003 Explorer limited Stock 2002 - 2005 Explorers 4
T How to replace the front wheel bearings on a 2003 Ford Explorer XLT. Stock 2002 - 2005 Explorers 11
C More front end clunk - but I've replace almost everything! Stock 2002 - 2005 Explorers 16
Q What is the best way to replace the front bumper cover? Stock 2002 - 2005 Explorers 10
9 Replace front and rear brake pads? Stock 2002 - 2005 Explorers 2
G Replace all 4L timing chain & guides without removing engine or special tools Stock 2002 - 2005 Explorers 20
S Rear wheel bearings replace and rear diff ????? Stock 2002 - 2005 Explorers 13
R 02 Explorer Ball Joints-What Else To Replace Stock 2002 - 2005 Explorers 14
Y Replace fuel filter with aftermarket Stock 2002 - 2005 Explorers 0
L 2003 Ford Explorer/Remove and Replace Steering Column-HELP Stock 2002 - 2005 Explorers 1
F Remove Middle Seat - Replace Seat Belt Stock 2002 - 2005 Explorers 2
S Replace jackshaft sproket? Stock 2002 - 2005 Explorers 2
E Should I replace O2 sensors in pairs? Stock 2002 - 2005 Explorers 6
D Replace water pump pulley? Stock 2002 - 2005 Explorers 9
F How to replace horn button. Stock 2002 - 2005 Explorers 2
M On the 4.6 is it possible to replace the cats as a unit without dropping the trans crossmember? Stock 2002 - 2005 Explorers 3
P 2003 V6 Air Conditioning - Replace/Repair Stock 2002 - 2005 Explorers 3
T Mechanic wants to replace my rear toe links for an alignment. Ripoff? Stock 2002 - 2005 Explorers 9
T Do I need a torque wrench to replace the upper control arm/ball joint? Stock 2002 - 2005 Explorers 5
L What to replace in AC rebuild Stock 2002 - 2005 Explorers 4
B 2002 Explorer - Replace Thermostat Housing and Hoses Stock 2002 - 2005 Explorers 4
R Need how to remove and replace bottom foam cushion Stock 2002 - 2005 Explorers 12
M Engine has been misfiring, should I replace parts bit by bit, or look at a system overhaul? Stock 2002 - 2005 Explorers 4
D TPMS Sensor Fault: Replace All 4? Stock 2002 - 2005 Explorers 1
S Tool kit to replace timing chains and cassettes on 2003 explorer Stock 2002 - 2005 Explorers 3
R Need to replace manual seat with power seat in 2004 Base Explorer. Stock 2002 - 2005 Explorers 6
R Need to replace manual seat with power seat in 2004 Base Explorer. Stock 2002 - 2005 Explorers 8
4 2XXk mile motor, doing chains should I replace anything else? Stock 2002 - 2005 Explorers 6
D Replace Timing Chains or Engine Stock 2002 - 2005 Explorers 13
R Replace upper ball joint boot only? Stock 2002 - 2005 Explorers 7
B 2002 Explorer - repair or replace? Stock 2002 - 2005 Explorers 6
imp Replace ABS Module Stock 2002 - 2005 Explorers 12
H How to replace the blend door? Stock 2002 - 2005 Explorers 11
D Replace timing sprockets or not? Stock 2002 - 2005 Explorers 1
F Do I need to remove timing chain to replace my head gaskets? Stock 2002 - 2005 Explorers 13
P Should I replace the Explorer Stock 2002 - 2005 Explorers 13
S I dont want to replace the rear hub/bearings. Stock 2002 - 2005 Explorers 15
2 Replacing Struts – anything else I should replace while I’m there? Stock 2002 - 2005 Explorers 4
W 4.0L SOHC - repair or replace? Stock 2002 - 2005 Explorers 3
Similar threads
