thebrakeman
- February 11, 2009
- Canton, Michigan
- 2006 Mercury Mountaineer
I'm tired of the power running boards on my '06 Mounty. Each winter, the boards seemed to be slowing down more, or not retracting all the way. Last winter I pulled the fuse to leave them retracted. Spring 2017, I tried removing them to follow the clean/lube procedure I found here. After breaking a weld-nut on each side, I decided to snug the remaining fasteners back in place while I still could. Now, back to winter, I've locked in retracted position again.
So, I want to find some fixed running boards, have painted if necessary, and let a shop cut the existing fasteners and install the fixed boards.
Has anybody done this? Are there aftermarket boards that won't look too "rugged" on a Mounty? What about the used market? I'm concerned about going to a junk yard, and getting stuck with more broken weld-nuts.
