replacing rear end
jabert
georgia
'99 and '01 Sports
The rear end on my 2001 Explorer Sport 4WD is shot. I have a low-mileage rear axle available for free to replace it and need to know if it's an okay swap or if there will be problems. Original axle code is D4 - 3.73 limited slip. Axle code for the replacement is 46 - 3.73 non-limited slip. Any worries?
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Yes, it will work fine. Is it from a gen2Explorer?
koda2000
x
No worries. I've done it.
jabert
georgia
'99 and '01 Sports
Thanks for the reassurance. The replacement axle is from another '01 Exp Sport, but not 4WD. I was almost certain there wouldn't be a problem, but wanted to be sure.
jabert
georgia
'99 and '01 Sports
Thanks! I was almost certain there wouldn't be a problem since the replacement is from another '01 Exp Sport. The different code and non-LS had me a bit concerned, though.
koda2000
x
There's no difference in the rear axles on 2WD's and 4WD's. You just have to make sure the gear ratios are the same if 4WD
