Reverse Glow - gen II | Ford Explorer Forums
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Okay I have searched, so I have seen plenty of pictures and the installation stuff
I am getting ready to pull my instrument cluster for a few reasons, 1 to install a new headlight switch, 2 to clean, 3 to swap to a different OD from the truck that donated my engine, etc
So I figure I would pick up a set of 1996 Reverse Glow gauges for my Ex
Just the white ones, no flames or anything.
My question is
Who has them and how do you like them???
Which brand to get or Ebay seller did you use?
Is anyone running a carbon fiber bezel or other bezel with the gages?
pictures and comments welcome :)
Thanks!
i did mine with some Knock off gauges...i recomend going with the real thing it is just a higher quality and after having mine for more than a year the cold weather crews with the speedo a little...other then that they are great and i have them wired into my headlights...(the blue wire withe the red stripe).
as for pics..ill post them in a minute
The wire needed for the dimmer
real thing = indiglow or what?
NU Image?
You nee I have no idea who makes the good ones
Thanks for the pics! Dont feel bad the faces I made for my BII I have re-done like 4 times, and they are peeling again hahahaha so one more shot........
here are mine...cheep overlays from ebay....they have a switch that goes between green and blue, and a dial for the intensity...sorry i dont have any of them glowing at night.
yes i mean real as in Nu image if you dont care about the peeling(mine are a little) then go with the non nu image. Mine were 30 bucks with shipping.
My gauges from ebay
attachment.php
SkanlaxJMO - your oil and battery needles look and hopefully are WAY off. You've got some crazy oil pressure in the night picture!
-Drew
I have the same ones as Drew ^^^^^
Anybody notice the overlays making your needles kinda sticky?
That is why I removed mine, sometimes the speedo wouldn't move till you were going 30 mph.Tach response was also slowed--maybe just the brand I had.
My overlays did it. I took the factory black off and used spray glue to adheir the overlay to the cluster. Problem solved.
You can also back the needles off some so they dont cetch.
oh my truck was off......haha my tach reads 800 rpm high....i might fix it this weekend.....also i have had the stickeness on mine too i think i might try and fix that this weekend too...ill keep you updated on what happens.
The other pic i had a bad alternator so....thats why the battery gauge was way off....the oil pressure thing is strange it reads all the way up and when i change my oil when i first start the truck it goes to the middle and once it circulates the gauge goes up all the way.
hi i have a 91 and bought some off ebay. they were kinda simple to install. and after i was done they looked great. really set mine apart from others. i kno not the same year but just thoght i could give u alittle insight. i would send a pic but havent figured how to work this site out yet.
Ebay ones from my 99 sport. I used spray adhesive and had no problems with needles sticking.
I will never ever buy them again. I did the glow and the reverse glow. They really screw up your needles in cold weather. they also do not line with well with the cluster lights, like 4wd and etc
