rockfx01
- April 19, 2007
- Chicago, IL
- '98 XLT
Hello, I am hoping someone with more experience will be able to help me. I'm trying to bring my Explorer back from the dead, it's been sitting for 2 years while I've been away at college. Now I'm back and ready to recommission it, but I'm having trouble getting it to start. The specs are:
1998 Explorer XLT
V6 4.0L SOHC
Stock engine parts to my knowledge, and up to date on at least engine related recalls.
The current condition is that it will crank(brand new battery) but will not start. There seems to be a fuel supply issue, but I wouldn't really know how to determine that. I did start the vehicle probably 2-4 mos. ago and it started, albeit a little roughly but I was able to drive it around a little while without a problem. Now it won't start at all. Here are some of the things I've checked/tried thus far:
1. Checked the plugs - Spark plugs look ok, more or less. I'm going to replace them anyway when I have a chance, but the ones that are in there were only a year, maybe 2 old when I parked the car. If needed I could pull one and take a picture of it. I don't really know how to tell possible problems by looking at the plugs.
2. Filled up with new fuel - The tank was pretty low by now. This is my primary concern because I didn't take into consideration when I stored it that condensation might form in the engine or tank. Therefore this is probably the biggest source of the problem. I was told by a mechanic to fill up with new fuel to dilute the old fuel and help the engine start. So far this has not seemed to help.
3. Used ignition spray to start the engine - Spraying a small burst of ignition fluid into the air intake does give a short rev when trying to start the vehicle. As soon as the ignition fluid burns off the engine immediately dies. This supports that the plugs are fine but instead there is a fuel supply problem.
I've just started this project and hopefully will be able to at least get it to start soon. Any suggestion on what to do? I believe the engine is reading error codes so I am going to try to borrow/rent a code reader sometime in the next week to find out what, if anything, it says. I'm hoping a complete rebuild is not necessary but who knows what problems there could be at this point. I am a bit suspect of the fuel pump, but have no idea how to check it. I do have the Haynes Repair Manual for my vehicle so if anyone wants to refer to that in helping me out, that would probably make it easier on both ends.
I appreciate any help anyone can give me. I don't know engine internals that well so I can definitely use your advice. Thank you!
1998 Explorer XLT
V6 4.0L SOHC
