Have to agree with Paxton,
You just can't plug the holes with a plug because you will get water inside.
You have to take the headliner out which means you take ALL the side plastic off. That also means taking the seat belts off with a tork socket.
Start by taking the crossmembers off and see what you think.
Something else some guys have done is turn the front one around and then run the back one right up to it. That doesn't look to bad either. Just an idea.
By the way Paxton, with all those parts you have down there you would think you would have a beater or two you come use next year at Moab or CCR run.
