andypalmer
- June 24, 2006
- Norfolk, United Kingdom
- '99 SOHC XLT
Hi all,
I have been having problems with rough idling on my 98 SOHC for a few months now. When cold it is really rough, this gets better as it warms but it is also rough when warm and in gear (D, R, 1 etc). Once I put it into P or N it gets a lot better. Also the roughness coincides with a slight drop in revs. Normally it is idling around 600rpm, a little low? I have also had error codes relating to O2 sensors detecting both banks lean and system adaptive detecting both banks lean and the both rich. I have had the 00M12 mod performed (front timing chain tensionner and all intake manifold gaskets). It seemed to improve a little but not a lot. Also my X has been converted to run on LPG (liquified petroleum gas) which is introduced into the air pipe around the IAT sensor so I can rule out anything on the petrol delivery system (pump, injectors etc) as it does it on both fuels. I am leaning toward the MAF sensor but I am not sure and have already spent a lot on this truck so am reluctant to waste much more money on this problem.
Any ideas?
Any ideas?
