David Kilmer
- January 30, 2018
- Ashland, OR
- 2000 Explorer XLT
So, I just recently replaced the cylnder heads on my 2000 explorer OHV , everything went perfect. Slight exhaust leak but new exhaust manifold to head bolts fixed that. I was losing a bit of water, and when it was hot, it was dripping off of the engine like another gasket was bad. I let it sit for two days and drained the coolent, as soon as I did, one of the freeze plugs started leaking from a tiny little hole. Awesome, easy fix. I inspected the other four and they all looked good. Got it out, went and got a replacement rubber one, came back to install it and realized the oil dipstick is in my way. No biggy, I will just unscrew it from its housing, again , and I do, and I put in the plug..... but now, I realize, this damn plug isn't going flush with the block, and now the dipstick is giving up its real estate to this plug that is now protruding from the block.
So, either I need a more shallow replacement plug ( this one was just what they had in terms of the diameter size of the plug ) , or a different dip stick.... or could I actually install a metal type plug? I know I can get away with plugging the dipstick hole, but I don't want a ten minute operation everytime I want to check the oil. Any ideas?
