Explorer Pete
- April 18, 2010
- Sacramento, Ca.
- 2013 Explorer Limited 4WD
Got a 2013 used Explorer Limited 31K back in Nov of last year. The drivers seat has the feeling that it is lacking in support at the tailbone. Had Ford dealer check, "said that they found something wrong, and replaced the cushion. All of this is under what was left of the warranty, 3/36K. After driving for a few days, and going over the 36K, I find that the seat still gives the feeling of lost support. I checked the right side and driver seat to see what type of support they both have. I found that the right side (passenger) seat has an added piece of support, the driver seat does not. It is a foam pad with firm plastic on one side. Checking on line, both cushions have the same part number. Sorry for the long lead-in, Can someone help explain why the support is not in the seat that is needed? I am sure the ford will stick to the fact that the cushion is correct. I am starting to get the feeling that I am out of luck. No butting of heads as of this time, but it is coming. How can I get the support that is needed for the seat? Pete
