wesalexleft
- August 2, 2009
- Memphis, TN
- 2003 Mountaineer V8 4.6L
I'm installing new o-ring servos into a 2003 Mountaineer with the 5R55. I'm having a problem getting the new servo in far enough to install a new snap ring. Before beginning work, I adjusted the band to 10 ft/lbs, and then backed the adjuster off a full two turns. I can get the new servo in so far, but just not enough to reveal the snap ring groove. I even backed the adjuster off another 1/2 turn to see if that helped, but no go. Anyone else have this problem, and how to fix? The instructions say not to remove the new servo once it's in place, because it will cut the oring on the way out...
