shift motor replacement | Ford Explorer Forums - Serious Explorations
thunderhorse
Elite Explorer <br><img src="/forums/images/icons/
Nashville Tennessee
2001 Sport Trac 4x4
Ok the shift motor on the T-case finally died, should be an easy fix. NOT! The motor coming out has two plugs the one going in (new motor) only has one plug. Anyone already done this? Need to know what wires need to be spliced.
Moving to Transmissions and Transfer case forum, where this will get faster help.
Worst case scenario, you could rebuild the old shift motor and see if that fixes it ;) (there's a 'how-to' on shift motor rebuild somewhere). If you find anything broken in the old shift motor, maybe you could take parts out of the new one.
The "How To" is in the stickies section at the top of this page. It is the most popular thread in this forum.
Been there done that about four times. Thought it was about time to go with new, maybe have to use new internals, old wiring and housing.
thanks for the help guys
