JKB2
- February 8, 2004
- Portage, Michigan
- 1999 2dr Sport
Hello,
I have a '99 4WD 2 Door Explorer "Sport" package with the 4.0 SOHC engine and 4 speed automatic transmission. The unit now has 187,000 miles, mostly highway. The wife uses it for work.
The truck has been great. Other than the timing chain rattle issue, and new front hub bearings on both sides, it's been a solid performer.
About two weeks ago, when shifting from drive to reverse at a dead stop in a parking lot, I heard a "grinding" sound, exactly like you would hear if you tried to force a manual trans into gear without depressing the clutch pedal. I flipped it into neutral, then back to reverse, and no problem.
Then, about two days later, we were crusing at speed (70 mph with cruise control engaged) when the same noise happened, and I quick hit the brake pedal to kick off the cruise. A loud "thump" from the trans, and away we went with no further incident.
Saturday, this past, we are headed over to Port Huron Michigan, from Kalamazoo. Cruising again, at 70 when the thing just revs like crazy as if the trans went to neutral. I hit the brake again to kill the cruise, and no thump this time, just back to drive as if nothing happened.
Well, all was well until the ride home tonight.
I started noticing a little surge on the highway. Like, the thing was slipping out of gear for a 1/4 second. Little "thump" sounds from it. All the way home, it gets worse...and worse. Only under load. Accelerate, or climb a hill, it's bad. Decelerate, or coast down a hill, nothing. No symptom.
By the time we get it home, it's very bad with loud under floorboard noise and thumping. You can feel it in the driveline, but the transmission is shifting fine through all gears (even into O/D) and I tried engaging the 4WD high to see if it made a difference. It didn't, except I now could feel the impact to the front as well as the rear. The symptom is sporadic, not timed to engine or vehicle speed. It might do it twice in 2 seconds, then not again for 4 seconds, then once...ect. I manually shifted all gears, and it does it regardless of what gear I am in. I tried turning off the O/D with the button on the column shift stalk, and it didn't matter. There are no lights, blinking or otherwise from the dash.
If I could describe it accuratly, it sounds / feels like a spline slipping and catching, or perhaps what a clutch slipping and grabbing might feel like.
But I really have no clue.
Your ideas would be helpful. I have no experience fixing 4WD as this is the first I have owned. I'm betting it's the transfer case, but really don't know.
Anybody else experienced this type of failure?
Thanks in advance,
JKB2
Thanks in advance,
JKB2
